Gsr swap into 93 hatch
Ok i know im going to make an *** of myself but i will be getting a gsr swap into my 93 dx hatch which as of now has an ls engine in there. Ive been told i need to change out the front rodors. Is this true ? Can i keep the stock rotors for now because i have hx wheels id like to keep?
Or are there any other things i can do ?
Thanks
Thanks
Re: Gsr swap into 93 hatch (JDM_Ej)
you can use all of your stock stuff, i put a gsr into my 94 hatch which had an ls in it and i was dissappointed in what the differnce between the two motors was, i ran a 14.6 with the ls with cams and cam gears, and with the gsr ran a 14.5 with the same tranny which is a gsr true lsd.
Re: Gsr swap into 93 hatch (jdmhatch21)
dAMN I run that in my 93 hatch w/ z6 motor w/ boltons. Actually Ran 14.6 @ 99 but that was because I was spinning my tires through third..
Re: Gsr swap into 93 hatch (hatchfem)
no, you dont need to change the rotor, u can use stock rotor. i have the same set up and i luv it.
92 eg hatch powered by b18c
ported n polished head
type r cams
ferra valves, titanium springs, and retainers
dc header
full catback
nkk stage 1 clutch
tein spring and tokico shocks
type r cams
dc header
full catback
nkk stage 1 clutch
well do you guys think i should go for the gsr or just keep my ls some people have made me think that there isnt a big difference in the two except loosing torque by going with the gsr.
Oh yeah and im trying to go for all motor no turbo thats why i figured id do the gsr instead of ls.
yellowredR
08-09-2003 11:40 AM
