how to mounting gsr front sway bar on ek
what do i need to mount the front gsr sway bar on my ek?
according to this thread:
http://www.ek9.org/forum/suspension/...formation.html
in order to use the front gsr sway bar i need civic ex flca and endlinks (the vertical ones). this is what i heard from the article. i have the ex flcas already but the civic ex endlink doesnt seem to work with the gsr sway bar. i've looked online and seen one person using gsr endlinks bolted downwards with the sway bar bolting to the endlink under the flca. is that the correct way to mount it? i thought the endlink would be on top of the flca.
anyone with front gsr sway bar on their 6th gen wanna some info?
Re: how to mounting gsr front sway bar on ek
To use the GSR bar, you need to use GSR end links. Yes it mounts stupid and yes you'll have some ground clearance issues since the sway bar has the loops that dip down towards the ground. If you want a bigger sway, just get a 99-00 Civic Si sway or even an EX sway even though it's a little smaller than the Si. They both fit nicely and they don't rob tons of ground clearance..
