GSR into EG6 Shift Linkage
I have a GSR engine swap ready to go, but I have one question before I lay down any money. For the GSR into my EG6 Hatch (dx) would I use a stock 92-95 shift linkage for my car, or a shift linkage for the integra? I cant find a straight answer anywhere and I used the search option.
aXhatch
aXhatch
Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy »</TD></TR><TR><TD CLASS="quote">You don't have a EG6.
You use the 94+ integra shift linkage.</TD></TR></TABLE>
or the 95+ del sol (DOHC)
Mr. Badwrench
Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
or the 95+ del sol (DOHC)</TD></TR></TABLE>
WRONG ANSWER DEL SOL VTEC LINKAGE WILL NOT WORK IN A HATCH.
unless you plan on cutting and welding, sorry about the caps, but i have tried it when i did my first swap and got burned by that.
Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">sorry, could of swore it would, being that the motor bolts up the same. thanks for correction </TD></TR></TABLE>
motor bolts up the same, but the del sol has a hump running down the middle of the cabin of the car that the civic doesn't.
Re: (IHateJDM)
you see, when i did my swap i already had the linkage. it acually came off of a eg6(it was a front clip). i simply bolted the motor as well as the linkage w/ no problem, then again it was a auto to manual swap so i drilled and mounted the linkage.
what linkage does the eg6 come with?
it was a gold color if that helps.
Re: GSR into EG6 Shift Linkage (aXhatch)
I was looking at an SiR swap, full front clip, but for that my prices were about 4k, and to get a GSR with LSD, mounts and stuff from hmortors & hasport, the total would be about 4k, maybe a bit under so i decided on GSR.
if my car isnt an EG6, as you say, then what would you call it. cuz i know i gots me an eg6. its a '93 hatch.
then is the "EG6" then is the "eg6" the si model? i see my mistake, in my original post i did put "dx" its not a dx, its a 93 teal si 1.6.
but that wouldnt be a eg6 either cuz its not dohc..
ok im cool i got an EG. no clue as to the numerical component though. but i get the idea with the EG6 mishap and am sorry i was stupid an got served.
Modified by aXhatch at 12:12 PM 11/10/2005
What they mean by saying "you dont have an EG6" is that if you had an eg6, with came with a dohc vtec engine from the factory, then you would already have the correct shift linkage needed to do the conversion. You also stated its a DX, therefore not an SiR. People usually generalize an eg6 as every 92-95 hatchback, but the eg6 is a specific vin code used to denote the SiR model 92-95 hatchback which came with the b16a engine stock from the factory. Therefore an eg6 is not an American DX hatchback which came from the factory with a sohc d15b7.
I understood you, but correct chassis code usage does make a difference when explaining problems because people know what features each car had/has and can then help you with your decisions/problems.
So in the future, just say 92-95 DX hatchback. It'll be easier and cause less confusion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aXhatch »</TD></TR><TR><TD CLASS="quote">if my car isnt an EG6, as you say, then what would you call it. cuz i know i gots me an eg6. its a '93 hatch.</TD></TR></TABLE>
Don't be so ignorant. You have an EH2.
Re: GSR into EG6 Shift Linkage (Del Sizzle)
thanks del-sizzle for the thread. answered all of my question i can think of. wonder why it didnt show up under "search" options...
cool
cool
donvito#1
16
08-13-2016 11:18 AM
AzntaggeR
12-23-2003 09:34 PM
93civic_b18b1
08-27-2001 02:09 PM
