does a GSR shift linkage fit in a del sol?
TSPeed Factory
i'm going to swap a B18C1 pretty soon and i need to know if the GSR shift linkage i have will fit into a del sol. i know a del sol vtec shift linkage will work, but if the gsr shift linkage fits that would be even better. or could i maybe modify my current shift linkage for a d-series motor to fit up to a gsr motor?
Re: does a GSR shift linkage fit in a del sol? (AzntaggeR)
Ive been told the VTEC Del Sol linkage is the only one that works, but i may be wrong.
As for moding a shift linkage, if you cut the bar and weld it back together it becomes weaker, and if its not aligned right on, your always going 2 have a difficult time shifting...
you can only use the delsol b series linkage. The integra linkage wont work due to it has different bends.
Re: does a GSR shift linkage fit in a del sol? (salbaje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salbaje »</TD></TR><TR><TD CLASS="quote">you can only use the delsol b series linkage. The integra linkage wont work due to it has different bends.</TD></TR></TABLE>
Mostly because the Del Sol shifter sits a good 6" higher than a Civic or Integra. If you look at a Del Sol shift linkage (SOHC or DOHC) next to an Integra linkage, it's bent like a "C" and the shifter is much higher.
TSPeed Factory
Re: does a GSR shift linkage fit in a del sol? (Newman)
alright. so when i order a b-series shift linkage for the del sol will i need the stabilizer bar as well? or will my existing stabilizer bar work with the del sol vtec shift linkage?
skiracer8148
03-17-2007 05:09 PM
SOLvtec
10-27-2006 09:30 AM
underpressure02
06-21-2005 03:28 PM
