rear disc swap
I'm not Rick!
Re: rear disc swap
you have to get the brake cables from a hatch or coupe ek that had disc brakes, your drum cable wont work. while your at it switch out the trailing arm bushings..spray the bolts with lube and let them sit...i didnt and busted 3 bolts with a breaker bar...sux
Re: rear disc swap
you wont notice much of difference dont even bother with all the work and labour.
if anything go for integra rears and fronts along with a 1in m/c only then would you notice a difference!
Re: rear disc swap
they are integra rears and i already have ex/si fronts with si prop valve and m/c and booster
Re: rear disc swap
but just to be clear the DA rear set up will bolt onto me EK even though the TA bushings are different
and thanks for the response
sj-performance
07-14-2009 07:55 PM
NathanMorris
02-09-2008 11:59 PM
ncVTEC1313
06-03-2004 05:14 PM
