A Good Fuel System/Injector Cleaner Every Oil Change
Do you people use a good fuel system/injector cleaner every oil change? Is it necessary? I use Duralube fuel system cleaner every oil change and I've been doing it for about 5 years now. If you do what do you use?
Re: A Good Fuel System/Injector Cleaner Every Oil Change (Guam_CiviC619)
I use seafoam about every other oil change...dont really know if it helps though...
Re: A Good Fuel System/Injector Cleaner Every Oil Change (SLPR)
i take this **** from work. gumout injector stuff..i run it through a vacuum line..usually the brake booster...works good on highmileage motors. smokes a lot tho for awhile (thats how u know its working tho)
if u want to do an engile oil flush..dont waste money on the gimmicks..i just add like a quarter quart of ATF fluid in the oil cap..let it run for 5 minutes..drain the oil..flush new oil through it...then do the oil change like normal. why atf? it has detergent like properties(more so then other fluids for clarification)
[Modified by JaeOne3345, 9:21 PM 8/29/2002]
[Modified by JaeOne3345, 10:21 PM 8/29/2002]
Re: A Good Fuel System/Injector Cleaner Every Oil Change (JaeOne3345)
isnt all oil detergent oil ??
only reason I see to flush is if you have an engine with 25k on it and no oil change EVER.....
Re: A Good Fuel System/Injector Cleaner Every Oil Change (Doctor CorteZ)
Thread started to go a little of topic. Let me clarify the topic. I'm wondeering if there's anyone out there that uses a concentrated fuel system cleaner once in a while? I use the Duralube fuel system cleaner every oil change. Here are a couple of examples of fuel system products: Duralube, Slick 50, STP, B-12 Chemtool, Shogun Import Fuel Sytem Cleaner (pennzoil), Greased Lightning, etc.
I use the stp brand. but i dont do it every oil change. usually at everyother one. i dont think that it can hurt anything if u do it that often. the people that make those cleaners recommend it at every oil change for 3 reasons, 1 for money, 2 to help ur car a bit, 3 money. just my 2 pennies.
New User
Re: A Good Fuel System/Injector Cleaner Every Oil Change (POS Hatchback)
If Honda thought you needed that stuff every oil change for the engines THEY MAKE I think they would recommend it in the manual or something.
I use one about once a year or less.
Also, nothing is better than the fuel injector can cleaners you hook up to the fuel rail and let your car run on that until the can runs out. Every race pro Ive seen use that over gas additives.
[Modified by samdawgsol, 1:16 AM 9/4/2002]
HT White Ops
if u want to do an engile oil flush..dont waste money on the gimmicks..i just add like a quarter quart of ATF...
Re: A Good Fuel System/Injector Cleaner Every Oil Change (BlackDeuceCoupe)
gumout....the **** yellow one...i forgot what its called, regain? something like that, highly recommended by many...i do it when i remember...about 10k or so
Re: A Good Fuel System/Injector Cleaner Every Oil Change (mindtrix)
i get the 4 pak techron at costco and use it every 10k..but i dont feel any difference when im using it..a clean gas is probably just as effective since they have a good concentration of cleaner in them
Re: A Good Fuel System/Injector Cleaner Every Oil Change (deepnite)
has anyone used the restore products? it comes in the silver can and they gaurantee results after 500 miles, i just put a can in tonight- i'll have to see how it works
