fuel in spark pluggs??
Old 11-09-2006, 09:41 PM
robert_v's Avatar
Default fuel in spark pluggs??
for some reason the fuel keeps getting into my spark pluggs. (the end that goes to the pistons).
96 hb:
b16a2
stock head
skunk stage 1 cams
ctr pistons
ngk iridium spark plugs
oem 3 layer head gasket
oem spark plug wires
timing is right
p28 ecu (jun chip)
Modified by robert_v at 11:00 PM 11/9/2006
Old 11-09-2006, 09:54 PM
Help we my pennies
BLUE EH3's Avatar
Default Re: fuel in spark pluggs?? (robert_v)
bump
Old 11-09-2006, 10:03 PM
Sketch_hs's Avatar
so it doesn't run? what are you trying to say?
Old 11-09-2006, 10:21 PM
robert_v's Avatar
Default Re: (Sketch_hs)
when the swap was done the motor started up but had some back firing, the throttle response was slow and the car took a long time to pick up. so we thought it was the timing and so we rechecked the timing and it was off a teeth on the exhaust side. timing was then corrected and now the car does not start up. every part i used was oem to put the motor together (head set, timing belt). grounds were rewired and we added more. but now when we checked the spark plugs, you can smell the gasoline on it
Old 11-10-2006, 10:53 AM
truevietluv636's Avatar
is it only one spark plug or all of them? maybe leaking fuel injectors...
Old 11-10-2006, 04:28 PM
robert_v's Avatar
leaking all four
Old 11-10-2006, 04:47 PM
f20bej1's Avatar
Default Re: (robert_v)
check the dizzy if it is tdc. if you light spark to fuel it would fire .no spark=and you have fuel=dizzy
Old 11-10-2006, 05:36 PM
Sketch_hs's Avatar
yep check for spark
Old 11-11-2006, 04:56 PM
robert_v's Avatar
there's spark, timing is right (manually cranked), distributor is also tdc. cant find a obd2a ecu to read check engine,
here's another question. i dont have a crank position sensor, i cant find anything on the 96 ex wire harness to match it up to the 99 si cps, are they different?
but there wasnt a problem before hand with the p28 starting the car.
Old 11-12-2006, 07:16 PM
robert_v's Avatar
bump
Brandeno
05-31-2015 08:55 AM
kamakaze1
05-29-2007 08:31 AM
SimplyTron
02-19-2007 12:08 PM
R_type
06-01-2005 01:48 PM
ludetech
05-20-2004 10:33 AM
Quick Reply: fuel in spark pluggs??
