fuel pump fuse keeps blowing (ek hatch)
Old 12-02-2013, 08:12 AM
b16_coupe's Avatar
Default fuel pump fuse keeps blowing (ek hatch)
Hi everyone, my 15 fuse under the hood keeps blowing as soon as I turn the key to on and the fuel pump doesn't prime. I don't know how to find the shortage so if you can help me, I might need a lot of detail. Thanks in advance. 96 ek hatch.
Old 12-02-2013, 02:28 PM
DvrkLord's Avatar
Default Re: fuel pump fuse keeps blowing (ek hatch)
Try putting a higher amp fuse and see if it blows.
Old 12-02-2013, 03:08 PM
carlos8's Avatar
When you turn the key to ON position do you hear the main relay click?
Maybe your pump it's seized causing the fuse to blown!
Do not put any higher fuse before check your problem if something is wrong you can damage something else. i.e. toast the wires
Put another fuse, lift the pump lid under the rear seat disconnect the plug for the pump and turn the switch to On. If the fuse don't blow check what voltage you get, if you get the correct voltage then your pump is damaged.
Old 12-02-2013, 04:06 PM
Former User's Avatar
Disregard this^ dangerous suggestion.
Old 12-02-2013, 04:09 PM
The hood 15A ECU fuse does not supply voltage to the fuel pump.
Try unplugging the IACV, fuel injectors, and ECU connector A to see if this prevents the fuse from blowing.
Old 12-20-2013, 12:24 PM
b16_coupe's Avatar
Which one is connector A and where is is my IACV Connector? Pics would be great...
Old 12-20-2013, 01:20 PM
B_Swapped93's Avatar
Google...not everything is spoon fed here, the iacv is on the intake manifold not hard to find.
Old 12-20-2013, 02:08 PM
b16_coupe's Avatar
ok I will get back to you guys
Old 12-22-2013, 11:59 AM
b16_coupe's Avatar
Sorry I got back to you kinda late, but here's what happened. I went and unplugged my injectors and moved around some wires behind the intake manifold And when I turned the key my fuse didn't blow. I plugged the injectors in expecting the fuse to blow but it didn't. I even turned on my car and starts like normal. Does this mean the short could be behind the intake manifold?
Old 12-22-2013, 02:40 PM
could get in there and look where the wires when into the injector clips is also a place to look. You'll need to slice the loom open.
Old 12-22-2013, 07:07 PM
nub
nub's Avatar
There's a TSB for this...http://www.tegger.com/hondafaq/tsb/civic/x99-029e.pdf
Old 12-22-2013, 11:39 PM
Shit Posts: 15
JDMswagSerf's Avatar
Totally agreed
Trying to break his pump?
My Honda Blows
12-22-2022 02:12 PM
bigodub93
09-30-2010 08:17 AM
fastludeh22
12-21-2003 08:50 PM
13BT
09-04-2003 11:27 AM
DCStreetHtch
02-25-2003 10:14 AM
Quick Reply: fuel pump fuse keeps blowing (ek hatch)
