Front Sway Bar Won't Fit my EK
Old 06-25-2004, 08:14 AM
Rice Ball's Avatar
Default Front Sway Bar Won't Fit my EK
I brought my 2000 Hatch Back DX to install front and rear sway bars. I bought eibach sway bars for 2000 Civic SI. The rear fits just fine but the front won't fit. The guy at the shop told me that if I put it on, the bar will hang really low and it will scratch so badly.
He recommended me to buy SI cross member from junkyard and swap it with my existing one. It will cost me about $300 for that alone.
So the questions are...
1. Is he right about the sway bar hanging too low on DX's crossmember?
2. Is there any sway bar made just for the DX?
3. If I really have to swab the crossmember, how much is it to buy SI crossmember?
4. Any suggestion for this situation?
Thank you
Old 06-25-2004, 08:31 AM
Rice Ball's Avatar
Default Re: Front Sway Bar Won't Fit my EK (Rice Ball)
Bump!
Anyone? Already searched but can't find the info I need.
Old 06-25-2004, 08:34 AM
deeksmooth's Avatar
well i have a 99 DX HB... i installed a front 00 SI sway. i had to get front 00 Si LCA's and forks to make it work.
i don't know, maybe the eibach hangs lower. i'd just install the OEM one, its 26mm.
Old 06-25-2004, 08:35 AM
el diablo
Built to Spill's Avatar
If you buy Si front LCA's and forks and install them onto your DX, then the newly bought SI front sway bar will fit your DX.
Old 06-25-2004, 08:38 AM
Rice Ball's Avatar
Default Re: Front Sway Bar Won't Fit my EK (Built2Spill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2Spill &raquo;</TD></TR><TR><TD CLASS="quote">If you buy Si front LCA's and forks and install them onto your DX, then the newly bought SI front sway bar will fit your DX.</TD></TR></TABLE>
how much would that cost?
and when you mean the sway bar will fit, you mean the eibach that I bought right? not the oem one?
Old 06-25-2004, 08:58 AM
el diablo
Not 100% on the cost. Should probably cost you no more than $200 per pair new. Im sure you can find them used for alot cheaper. I sold my ITR front LCA's for $100 shipped. As far as the Eibach bar fitting your car, it should very well fit your car as long as you have the SI front LCA's. I know it wont fit on your car now, because DX front LCA's dont have the mounting holes for swaybars.
Old 06-25-2004, 09:29 AM
Rice Ball's Avatar
Thank you for the info.
So when the guy said I needed the crossmember, that's not true? I was kindda disagreed with him too, but hey, who am I to argue with the pro?
Beside the front LCA, would I also need the forks?
Modified by Rice Ball at 6:41 PM 6/25/2004
Old 06-25-2004, 09:43 AM
el diablo
Anytime .
Not sure why he recommended a new crossmember.
edit: I would recommend purchasing the forks.
Old 06-25-2004, 09:55 AM
mjrage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rice Ball &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by Rice Ball at 6:41 PM 6/25/2004</TD></TR></TABLE>
Always argue with the Pro.
Old 06-25-2004, 09:58 AM
Jon V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2Spill &raquo;</TD></TR><TR><TD CLASS="quote">Anytime .
edit: I would recommend purchasing the forks.</TD></TR></TABLE>
Why do you need the forks?
Old 06-25-2004, 10:03 AM
el diablo
Default Re: Front Sway Bar Won't Fit my EK (Jon V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V &raquo;</TD></TR><TR><TD CLASS="quote">
Why do you need the forks?</TD></TR></TABLE>
DX forks dont fit on Si LCA's.
Old 06-25-2004, 10:05 AM
b18c1eg
Guest
Posts: n/a
because the area on the Si control arm where the fork bolts to is thicker. you will also need Si lower damper fork bolts as well. i just went through this with my CTR arms. (same as 99-00 Si)
Old 06-25-2004, 10:16 AM
Jon V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2Spill &raquo;</TD></TR><TR><TD CLASS="quote">DX forks dont fit on Si LCA's.</TD></TR></TABLE>
Thanks you just saved me an extra trip to the junk yard
Old 06-25-2004, 10:20 AM
Rice Ball's Avatar
What do you guys think about these threads?
https://honda-tech.com/zerothread?id=677413
https://honda-tech.com/zerothread?id=873449
Old 06-25-2004, 10:27 AM
el diablo
Seems like a reasonable deal, and from the pic it looks like its pretty good quality. If thats what you want. Personally i would do it the right way.
Old 06-28-2004, 10:09 AM
Rice Ball's Avatar
Is it true that the ST sway bar will fit right onto my 2000 Civic Dx?
xeejay
12-17-2014 11:10 AM
RetroGamer
33
08-19-2011 03:50 PM
spoonfed*ek9
Suspension & Brakes
08-26-2008 06:32 PM
The Lobster
03-19-2007 01:54 AM
'99 HB Hank
06-21-2002 01:56 PM
Quick Reply: Front Sway Bar Won't Fit my EK
