Front Stabilizer Bar for EX coupe replacement - What do I need from an Si or GSR?
So I have a coupe and have a means of attaining a front stabilizer bar, I know the mounts are different. What all do I need to do this or is it even worth ******* with? Do I need to get the whole front arm assembly from an Si so the mounts will work? They are different part #s (the front arms)
Will a GSR front sway bolt on?
Thanks guys!
Thanks guys!
Re: Front Stabilizer Bar for EX coupe replacement - What do I need from an Si or GSR? (greebler)
i didn't think that the gsr bolts on, but i don't know for sure. as for the si, you will also need the lcas and wishbones for the shocks.
Re: Front Stabilizer Bar for EX coupe replacement - What do I need from an Si or GSR? (kommon_sense)
why the wish bones from the bottom of the strut?
Appears to be the same
you could get some aftermarket swaybars, from suspension tech, etc. that you use with your existing lcas.
the forks on SI's are wider where they attach to the LCA.
You would need the swaybar, endlinks, bushings, LCA's and forks to put an SI sway bar on any civic that isn't an SI.
Re: Front Stabilizer Bar for EX coupe replacement - What do I need from an Si or GSR? (tominos)
Yea I know, but I saw a bunch at a local junk yard and could pick on up for cheap. As car as the rear, I could just get a Skunk2 for like $100 or so.
Shaynepolevault
11
05-24-2009 11:33 AM
bboygreddy
12-05-2006 09:25 AM
chillly
12-21-2002 06:53 PM
