Fog lights not working - how to test them?
I have a 96 civic hatch with the yellow fog lights that everyone else has installed. The problem is they were put in by the previous owner and for some reason don't work. I would love to avoid uninstalling and redoing it myself because everything looks like it's wired correctly. Is there something I should check with a multimeter to be sure everything is wired correctly? The fuse is not blown or anything.
Re: Fog lights not working - how to test them?
You said it looks wired correctly I would go through and double check, then get out multi meter and check from the battery down to see where the problem is. Here is a link if your not sure how it should be http://www.handa-accessories.com/civ...cfoglights.pdf
Link is bad or copied/pasted incorrectly from source.
So I worked on the lights a little more today. Realized I had a bad bulb, replaced it, still nothing. If its not the fuse, relay or bulbs, then its safe to assume whoever installed it just wired it incorrectly? I dont have the instructions so i'm stuck for now. When I press the switch, the switch itself lights up, just not the actual lights -_-. Maybe I can figure it out if someone can tell me where the negative line connects to complete the circuit? The positive goes to the battery obviously but I have yet to find the end to the negative.
Was hoping with the info I gave someone would be able to tell me something specific to check. I found plenty of DIYs but short of pulling it all out and starting over, they aren't much help. If I knew what and where to check with my multimeter everything would be gravy
sorry don't know why that link posted incorrectly
Nvm, figured it out. The guy I bout it from had it grounded to the radiator support. Should have checked that first :/
