HELP! reverse lights don't work!
Old Apr 14, 2004 | 02:56 AM
808style's Avatar
Default HELP! reverse lights don't work!
i have a 93 RS 5-speed and the reverse lights won't come on when i put it in reverse. the light bulbs are still good. any ideas on what/where to check?
Old Apr 14, 2004 | 05:02 AM
phat_gsr98's Avatar
Default Re: HELP! reverse lights don't work! (808style)
check the fuse??
Old Apr 15, 2004 | 02:36 AM
808style's Avatar
Default Re: HELP! reverse lights don't work! (phat_gsr98)
nah it aint the fuse, i checked um all. all the lights in the rear work except for the reverse lights.
Old Apr 15, 2004 | 05:40 PM
deepgreengsr's Avatar
do you get power to the wires back there. Next its probably a ground issue. Check the nearest ground for continuity or a short.
Old Apr 15, 2004 | 08:15 PM
xTravBx's Avatar
Default Re: HELP! reverse lights don't work! (deepgreengsr)
Theres like a plunger that trips the lights to go on, when you put it in reverse.. check your manual for where its at.. i bet its that..
Old Apr 15, 2004 | 08:59 PM
cougar10ag's Avatar
jack the car up.. go to the tranny and there should be a sensor sticking out the back near the shift selector. thats you reverse switch. pull it out and check for damage. clean it and reinstlal it. if light still don't work check wires for continuity. if you ahve power then you need a new switch.
EDIT. heres the gen 2 servic manual instructions for replacing it
http://www.redpepperracing.com/technical/102/aac
Old Apr 16, 2004 | 02:27 AM
808style's Avatar
Default Re: (cougar10ag)
thanks for all the replies guys. i'm gonna check out that sensor thing this weekend. right now i'm thinking that's the culprit since i remember seeing the reverse lights work a couple times before.
Techy
Dec 31, 2006 11:29 PM
fwdftw
10
Jul 24, 2006 05:31 PM
disposable
Sep 5, 2005 10:02 AM
rukawa1one
11
Feb 16, 2004 10:53 AM
BeeResp0nsible
Aug 29, 2002 07:24 PM
