HELP! Foglights wont turn on anymore!
i tried doing the fog light trick on my 00 si. i swapped the wires that were stated here: http://forums.clubsi.com/showf...art=1
the fog lights did not turn on, but the other lights did.
i rewired them the way they were originally, still no workie.
i replaced the foglight fuse, still no workie.
i dont know what else is wrong. any help is appreciated.
thanks!
thanks!
Re: HELP! Foglights wont turn on anymore! (EM1Guru)
try hooking the straight up to the battery to see if they still work, if they do, then you're doing something else wrong
Re: HELP! Foglights wont turn on anymore! (blackhatchy)
as of right now, the only thing i can think of is that the bulbs are blown, or i have a bad relay.
another thing i shouldve added is, that my green light in my switch wont light up anymore.
could be a bad switch. if the light on the switch no workie problem is the the switch no workie. connect them srtaight to the battery to see if the lights even work.
check fuse
OE fog light wiring diagram possibly here if you need it:
http://www.honda.co.uk/owner/workshopmanuals2.html
Re: HELP! Foglights wont turn on anymore! (zelifcam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zelifcam »</TD></TR><TR><TD CLASS="quote">check fuse
http://www.honda.co.uk/owner/workshopmanuals2.html</TD></TR></TABLE>
fuse has been replaced.
thanks for the link
thanks for the link
probably isn't grounded right, or you have a blown-out fuse, light bulb is burned out, defective relay, or it doesn't have power. check your wiring again too, if one wire is not connected, the whole thing wont work. try hooking up the power wire to the battery too as said above
rugimpy
11
11-07-2008 01:54 PM
