Cant get fogs to light up
i got some fogs on my EF. and they were working fine until i started messing around with the switches. then they just stopped working. i thought it was the switch at first cuz theres power coming out of the wire and its grounded but the switch doesnt even light up and i got a new one. so idk what it is???? anybody know. could it be the bulbs.
Re: Cant get fogs to light up
try the battery thing like crx si-r said. my buddy had the same thing happen except his bulb wasnt making good enough contact to light up.
yehhh my fuses are fine.all my connections are fine. i havnt tried the battery-fogs thing. but i dont think its that cuz my switch isn't even lighting up.
Are your using a non oem fog light kit that comes with the red light up switch? If you are then I know those come with crappy wires. Make sure the fog lights are both connected to the single wire that runs to the switch. It's normally like a "Y" set up. Then check each fog light ground wire. On your switch check the 3 wires that connects to it. You have the ground that lights up the switch(you don't have to use it, it only lights the switch up. Then you have one wire that runs to the fuse box for power. Last you have the wire that comes from the lights to the switch. Make sure all of those are on the right spot on the switch.
is it possible that when i was messing around with different foglight switches i could of hooked em up wrong and blew out my bulbs without knowing???
oright i tested the light bulbs and they turned on. so its not the bulbs or the switch or fuses. it has to be a bad connection somewhere. imma try and rewire the whole dam thing.
okay finally figured out what was wrong. the power wire that goes to the switch wasn't connected to a spot where it had power.
but now idk wheres a good spot to hook it up.
would it be safe to stick it into one of the fuses on the fusebox???
Bertsch911
11
12-24-2019 06:01 AM
taimysho0
17
01-17-2009 12:05 PM
