Which first, set idle or set ignition timing?
Old 04-29-2024, 04:19 PM
asdfalfa's Avatar
Icon5 Which first, set idle or set ignition timing?
Relaced both IAC and distributor/cap/rotor. Runs okay however, both idle and ignition timing are out of spec, MPG is not optimal, slight lack of power, and it occasionally throws a p0505 code - the throttle gets jerky and somewhat unresponsive, until engine is restarted. Once restarted, all is well until it inevitably happens again. Which should I set first? Idle, or IGN timing? To my understanding, each one needs to be set correctly to read the other. Please help me understand this, lol.
Old 04-29-2024, 08:21 PM
JRCivic1's Avatar
Default Re: Which first, set idle or set ignition timing?
Are you using a bone stock ECU ?
TruckeeEG
Engine Management and Tuning
03-31-2014 12:27 PM
xxxmikenicexxx
10-11-2009 01:03 PM
keebler65
10-02-2003 09:14 PM
TheHatchHog
05-13-2003 10:58 PM
non-VTEC
01-27-2002 12:15 PM
Quick Reply: Which first, set idle or set ignition timing?
