Finally went with a swap..
but have a few questions...
usdm 1997 b18c in a 98 ex
1. does any factory air box fit and line up?
2. my exhaust doesnt line up.. is this normal? resolution?
3. my ac is installed with the del sol bracket what belt do i need?
4. for power steering i have been informed that i need a si power steering pump? if this is true what belt will i need for that
thanks
thanks
HT White Ops
1. The stock civic airbox with a GSR intake arm should fit, but you may have to creatively position the arm.
2. I had to trim my exhaust when I put in my B18B. I just cut off a length and rewelded the flange.
Not sure about the belts.
Re: Finally went with a swap.. (oc_civic)
1) It's off by an inch, the rubber hose should be able to adjust (get an intake anyway) edit: the civic hose will never fit over the bigger throttle body
2) I used the JDM ITR 4-1 header bolted to a 2.5" blox flange welded to a 2.5" magnaflow cat welded to a 2.25" flange bolted to my apexi exhaust in the stock location
3) B18C A/C belt
4) if its a JDM ITR your EK hose will bolt right up to the orginal ITR pump, use the B18C belt
3) B18C A/C belt
HT White Ops
Re: Finally went with a swap.. (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">1) It's off by an inch, the rubber hose should be able to adjust (get an intake anyway)</TD></TR></TABLE>
He could just get a 3" black rubber coupler, that would probably squeeze it in. Some people like stock airboxes.
Re: Finally went with a swap.. (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
He could just get a 3" black rubber coupler, that would probably squeeze it in. Some people like stock airboxes. </TD></TR></TABLE>
theres no reason to keep a stock air box, a simple peice of pipe FTW
HT White Ops
theres no reason to keep a stock air box, a simple peice of pipe FTW </TD></TR></TABLE>
Aesthetics play a part
the stock airbox hose DID actually fit onto the motor.. but it was a little tight in the bending and i was afraid to brake the kevlar pipe...
the exhaust is just a few inches off so i figured it was going to be some welding some adapter..
the ex PS pump does NOT correctly fit onto the b18.. im pretty sure i need the SI one..
thanks any other info is welcome
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oc_civic »</TD></TR><TR><TD CLASS="quote">the stock airbox hose DID actually fit onto the motor.. but it was a little tight in the bending and i was afraid to brake the kevlar pipe...
thanks any other info is welcome</TD></TR></TABLE>
If it's short, then you have a few options:
1) Aftermarket header
2) JDM ITR Exhaust Manifold
3) Small Adapter
4) Omni-power Adjustable Test-Pipe.
3) Small Adapter
Ya, amen to that.
Ya, amen to that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oc_civic »</TD></TR><TR><TD CLASS="quote">but have a few questions...
usdm 1997 b18c in a 98 ex</TD></TR></TABLE>
if its a usdm motor it should have a # after the c if its jdm it will not...
Re: Finally went with a swap.. (01_CLtypeS)
soory its a b18c1 for clarification...
i got my ex intake arm and spoon kevlar pipe to line up.. finished cleaning up most of the wiring... can anyone confirm that i JUST need the teg ac fan belt..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">B18C A/C belt</TD></TR></TABLE>
ToTriggerHappy
12-01-2010 09:34 AM
ramz7887
12-06-2004 07:30 AM
EKtypeRhaTcH
11-19-2004 09:34 PM
