b18c swap into a 5g civic, lots of questions
1 Post
Ok well I am debating which engine to drop, I really havent reasearched the b18c as much as the b16a, anyway I have a lot of questions that need answers! :D
1. What modifications will I have to do to my engine to get the gsr engine to work, say if the engine doesnt come with stock air box?
2. What do I need to keep power steering/AC
3. Whats this about extending the something to get the exhuast to fit? dont really get that...
anything else anyone can add, I would really appreciate it
New User
Re: b18c swap into a 5g civic, lots of questions (navin)
well, i could answer one of your questions.
about the exhasut. theres going to be about a 3 inch gap so you need to go to a muffler shop and weld on a flex pipe or some other kind of pipe
Yes you can keep power steering and A/C. You will need the GSR power steering pump and mount and you will need the A/C mount from a DOHC Del Sol. Hope this helps.
Re: b18c swap into a 5g civic, lots of questions (Civicboy)
will i have to modify the exhaust on my b16 swap when i get it? on a 93 civic hatch
New User
Re: b18c swap into a 5g civic, lots of questions (DragonCTR69)
i believe b16 exhasut will bolt right up to the civic exhaust. could be wrong but im about 90% sure
Re: b18c swap into a 5g civic, lots of questions (rookie2nr)
Did you read the tech page on the Hybrid Board? All the info you need is there.
http://hybrid.honda-perf.org/tech/5gtech.html
Good Luck,
Good Luck,
kyliejohn1129
05-03-2012 07:59 PM
Kidnkorner
02-03-2011 05:52 AM
ooopseyesharted
03-01-2009 05:45 PM
