A Few Questions for my friends on H-T
ok guys my car is lowered alot
front end on ebay coilovers
and my back springs are cut
i have an ls in it
so the problem is it gets bad inner tire ware
how do i fix this
is it toe or do i need a camber kit?
And i need some parts PM ME if u haveeee
pass side front door trim peice (on side of window)
OEM washer sprays
and all the trim for my windsheild
thanks alot guys
i have an ls in it
how do i fix this
OEM washer sprays
thanks alot guys
Re: A Few Questions for my friends on H-T
Toe is usually the culprit. Go get an alignment and you should be good. If your tires are really bad, replace them at the same time as the alignment.
it is your toe and to fix it youd need a front & rear camber kit. get new tires and the camber kits then bring it straight to an alignment shop. also get rid of the cut springs & buy some lowering springs or coilovers. cut springs make your car handle like sh*t
Definitely need camber kit then an immidiate alignment. with a car "so" low you better hope the camber kit helps. I would look into getting new springs
killa4lyfe
13
06-29-2006 09:19 AM
madcrossover
10-19-2004 10:05 AM
