camber help
Old Dec 20, 2002 | 12:09 PM
VtecB17A's Avatar
Default camber help
whats up everyone, today i got my tires installed and my old tires were worn out very bad due to camber probs. the guy at the tire shop said that i need lowering springs adn not camber kits to fix the prob cause its not that bad. i cut my springs a long time ago LOL ok i know im stupid for doing this. but is it true that if i get lower springs it will fix the problem or a goop alignment. thanks.
Old Dec 20, 2002 | 12:13 PM
SupaTeg's Avatar
Default Re: camber help (VtecB17A)
Go and have them check the camber and see it that is causing the problem.
I never heard of springs fixing camber??
Old Dec 20, 2002 | 12:52 PM
PHAT-INTEGRA's Avatar
Default Re: camber help (SupaTeg)
Springs dont fix it you need to upgrade your camber kit or get it adjusted but in your case with cut springs I get new springs and camber kit and get it install at the same time then go for the wheel alighnment ASAP. That will fix your problem
[Modified by PHAT-INTEGRA, 4:52 PM 12/20/2002]
Old Dec 20, 2002 | 01:02 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: camber help (PHAT-INTEGRA)
New springs & Camber plates.
Old Dec 20, 2002 | 03:06 PM
VtecB17A's Avatar
Default Re: camber help (integra707)
thanks for the responses, i agree with u guys, but since the guy said that i thought id make sure since hes a "professional" where can i get camber kits and what are some good ones..im going to get H&R's hopefully this weekend if my wallet allows me to.
Old Dec 20, 2002 | 06:48 PM
VtecB17A's Avatar
anyone??? please
Old Dec 20, 2002 | 06:53 PM
NateTEG95's Avatar
I have brand new pair of ingalls in the boxes if you want to buy.
Old Dec 20, 2002 | 07:05 PM
VtecB17A's Avatar
Default Re: camber help (Lsintegra92)
send me the info @ vtecrb23@yahoo.com wit the price and stuff thanks
Old Dec 20, 2002 | 08:06 PM
VTEC-DA's Avatar
I have Progress kit in the front and the washer trick in the back and it works great. Also, which H&R were you planning to get? I have the H&R Race and its pretty low, just to let you know.
Old Dec 20, 2002 | 08:32 PM
NateTEG95's Avatar
Default Re: camber help (VTEC-DA)
I did the washer trick in the back also. I used two washers and it fixed it pretty well.
Old Dec 20, 2002 | 09:06 PM
ghettols's Avatar
forgive me for asking, but whats the washer trick? is there any like to show this method?
Old Dec 20, 2002 | 09:14 PM
NateTEG95's Avatar
Default Re: camber help (ghettols)
This is from the gen2 teg site check it out one the site there are pictures. Click on teg tips, then go to exterior, then scroll down to rear camber correction. I know that it works on gen2 tegs but I am not sure about gen3.
The Generation 2 Integra Club and those posting these tips stress that performing these tips/tricks are at your own risk.
No one will be held liable for error / injury but yourself.
Correcting Camber in Rear Wheels.
If you want to get rid of negative camber because it's eating your tires you can do this:
1- Jack up your Integra and remove the wheel.
2- There's an arm that attaches to the car right besides the gas tank when you look straight through the wheel well and it has two bolts attaching it to the car.
3- Remove these two bolts and insert metal washers between the arm and the car and reinstall again.
4- Number of washers or thickness depends on how low your car is dropped. Mine is dropped 2" in the back and I used (2) 1/16 washers at each bolt i.e. (4) washers for each wheel. If your car is dropped more you'll need more washers but have to get a longer bolt too. Good luck.
5- Camber correction for the fronts however requires purchasing a camber kit OR some really heavy duty modifications to the front fender OR bending the "spindles." (the last two are not good and not recommended)
Zaidoun
alibaba_23@hotmail.com
BattleCat
dghenso@prodigy.net
© G2IC.com 1997-2002. All Rights Reserved.
Old Dec 20, 2002 | 09:17 PM
ghettols's Avatar
cool..thanx
Old Dec 21, 2002 | 07:55 AM
I have Skunk2 in the front but there costly but I dont have rear ones yet but Im 2 lazy to do the washer trick but I heard is just as good as the rear camber but not the best on earth...
Old Dec 21, 2002 | 02:25 PM
ucb's Avatar
ucb
pro-drive sells a full front and rear camber kit fo 85 bucks. well they used too any way
Old Dec 23, 2002 | 12:23 PM
zilverz's Avatar
http://www.groupbuycenter.com
Old Dec 23, 2002 | 02:39 PM
Big Teggie's Avatar
Get a good set of springs.
Then go for an alignment.
Camber isnt what kills you tires, its the Toe. When you lower your car the suspension geometry is changed. You can keep the camber where it is right now, just get the toe set to zero front and rear. The tires should wear pretty evenly if rotated.
xbn83
May 15, 2005 01:03 PM
hondaracin24
Aug 27, 2004 08:28 AM
1ntensiveVTECivic
Aug 8, 2003 11:07 AM
00-0258
Jun 18, 2003 09:19 AM
Understeer
Jul 28, 2002 02:44 PM
