fast idle thermal valve
my fitv is apparently stuck open and my idle is high as hell as the time as a result of it (from my tuner not my guess fyi)
i have a b20 tb w/o a fitv and was wondering if it's alright to run it w/o the fitv?
Next if i do remove the fitv, where do i route the coolant line?
Thanks for any help
Thanks for any help
Re: fast idle thermal valve (CivicVX94)
if your not using the coolant lines then u re-route them back to the block where it ends up. haveing a throttle body without the FITV is like doing the coolant bypass where u put a gasket between the FITV and the TB im guessing. just try it out.
Re: fast idle thermal valve (lemon_juice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lemon_juice »</TD></TR><TR><TD CLASS="quote">if your not using the coolant lines then u re-route them back to the block where it ends up. haveing a throttle body without the FITV is like doing the coolant bypass where u put a gasket between the FITV and the TB im guessing. just try it out.</TD></TR></TABLE>
ya that makes sense.....thanks for your help
dem0nk1d
14
03-22-2006 05:57 PM
