inside of car smells like exhaust help
im not sure why but when i drive my car it tends to start smelling like exhaust fumes so i drive with the windows open. i havent found any exhaust leaks but im not sure what could be the problem. the a/c has been removed just for some info.
confused on what could be th problem
Re: inside of car smells like exhaust help (dvlsfan30)
take it to a mufler shop. you most likely have a exhaust leak. or little holes from rocks or rusted through on your cat. that or is your muffler all the way out the back of your back bumper or is in the bumper? behind it.
thanks for the help im thiking its the hole now from removing the a.c if not im going to get the exhaust checked out . i will update you tommorow
Re: (dvlsfan30)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvlsfan30 »</TD></TR><TR><TD CLASS="quote">anyone got a pic of where the holes on the firewall may be so i can see if they are plugged up?</TD></TR></TABLE>
You shouldn't have any exhaust expelled into the engine compartment. I recommend that you look for an exhaust system leak, as already mentioned.
DUKE LADUKE
12
01-19-2011 11:22 AM
xunkn0vvnx
08-24-2005 12:45 PM
