Engine Swap. Help!
Engine Swap. Help!
I'm about to do a swap on my 97 Ek. I have a 98 B20 block with a type r head. I have the B-series axles. I'm thinking of putting in a GSR tranny but they told me it's not recommended cause of the gear ratio(can anybody comment on that). Now they told me I still need the ECU and the mounts. Does anybody know what kind of mounts I need. Also any recommendations on the ECU, I was told SI was a good way to go especially if u wanna chip it. Please any body with any Input on this situation! Thanks
Re: Engine Swap. Help! (struggle51)
Get hasport mounts
the ECU that goes with the motor
GSR tranny should be fine
try to keep the tires on, this motor has a nice tourque curve
Re: (turbo-2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-2nr »</TD></TR><TR><TD CLASS="quote">well since it is a b20vtec you will need a chiped obd1 ecu </TD></TR></TABLE> overlooked the GSR head
Chipped P28 should work
b18civicdx
08-10-2004 08:46 PM
