boost Q&A
boost Q&A
ok, i found this little electric supercharger. Well the thing is it doesn't say how many psi it pushes just that it move 45sq ft of air a minute at 3500 rpm. So first does anybody know what 45sq ft of air a minute is in psi, second whats a safe psi to run on a basically stock engine? (header, short ram, exhaust system) the blower was only $10 so i figured why not, if anything get another. i also saw similar ones saying 2-3 psi.
Re: boost Q&A (dillonG_B)
E-superchargers are junk, waste of money and time, even the time you spend looking at it on the net. That $10 can destroy your motor too if the propellers inside break and go into your motor . Use that $10 and seafoam your motor, it would probably be worth more to do that.
