Engine Swap....
Engine Swap....
I need a new engine for my 1995 Honda Civic Hatch, but i dont know what i should go with and what will fit. I also want to keep my T3/T4 Turbo set up too. Any one have any ideas or where i could look for one?
Re: Engine Swap.... (theERAisBack)
assuming the motor you have now is the stock single cam and you want to kepp your turbo set up....go with a d16z6, you won't need to change anything to kepp your turbo kit.
if you went b-series you would need to tap the b-series oil pan get a new manifold etc. etc.....especially if you got a gsr motor your intercooler piping would need to be redone due to the different location of the throttle body.
Re: (ifIexplode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode »</TD></TR><TR><TD CLASS="quote">Hmotors</TD></TR></TABLE>
x2
http://hmotorsonline.com/shop/...gines
x2
Re: (01_CLtypeS)
Where can i get a D16z6 for a decent price? And isnt the B18b almost identicle to the D16, like the intake manifoild and what not? but i could be wrong. I kind of what a motor that puts out a little more but i dont want to have to do to much fabrication or custom work.
Re: (Doostur)
Would this motor wor. [URL]http://www.hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30005 [URL]
Cuz it has power and looks close to what the d16 is right now
Re: (DOWNwithHT)
Would it fit in the civic and is there anything wrong with it or have you had any problems with it, and do you have pictures? and could i keep my T3/T4 Turbo set up on that motor, and is jus the motor? or complete change over?
Re: (theERAisBack)
1. Would it fit in the civic and
2. is there anything wrong with it or
3. have you had any problems with it, and
4. do you have pictures? and
5. could i keep my T3/T4 Turbo set up on that motor, and
6. is jus the motor? or complete change over?
1. Yes, it is a direct fit (not sure about wiring the vtec in...?).
2. There is nothing wrong with the engine.
3. I have not had any problems whatsoever with the engine
4. I do have pictures, what is your email?
5. Yes, your turbo set up should bolt up the same way.
6. I am selling just the longblock engine, your tranny and intake manifold should work, but I'm not sure about the PS/Alt/AC...
Re: (DOWNwithHT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theERAisBack »</TD></TR><TR><TD CLASS="quote">Where can i get a D16z6 for a decent price? And isnt the B18b almost identicle to the D16, like the intake manifoild and what not? but i could be wrong. I kind of what a motor that puts out a little more but i dont want to have to do to much fabrication or custom work.</TD></TR></TABLE>
You're wrong.
Every part short of the throttle body and a few other pieces is different between the B18B1 and the D16Z6.
They're not identical at all.
D16Z6 for decent price? Junkyard for 2-300 bucks.
If you go with a B18B1 (LS) You're gonna need to swap over to all B components (change the mounts, change the linkage, change the transmission, then the turbo won't bolt up, so you'll need to buy a B series turbo manifold.
It'll cost a decent penny, get a D16Z6.
You're wrong.
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
Good luck with that in the upper-midwest. There is a very limited supply of good honda parts, and they are very expensive.
Re: (theERAisBack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theERAisBack »</TD></TR><TR><TD CLASS="quote">Would this motor wor. [URL]http://www.hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30005 [URL]
Cuz it has power and looks close to what the d16 is right now</TD></TR></TABLE>
here i fixed your link for you:
http://www.hmotorsonline.com/s...30005
and yes that swap should work as long as you get a 95 spec...Hmotors FTW
Re: (theERAisBack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theERAisBack »</TD></TR><TR><TD CLASS="quote">Okay and where do i get these from? I am kind of new to this so ...
Importautosalvage.com got my ls from there... clean as a whistle.
bigballing222
53
03-17-2011 02:43 PM
hondaman93
43
07-25-2007 02:32 PM
CobaltInfinity
18
05-07-2005 11:23 AM
redlineracer419
01-08-2005 09:35 AM
