Idle surging fixed, now car dies??
Old 01-24-2011, 09:41 AM
decko's Avatar
Default Idle surging fixed, now car dies??
Well I took my FITV off to try and fix my idle surging, turns out the white plate that holds the spring down was almost all the way unscrewed so I tightened it back up and put everything back together. Now on a cold start my car idles fine at about 1k-1100 and after its warmed up it's a steady 7-800. The problem is after it's warmed up if I go to the store and come back out and turn it back on, or if I sit at a stop light for too long the rpms slowly drop until it dies.. Any ideas?
Old 01-24-2011, 10:06 AM
Former User's Avatar
Default Re: Idle surging fixed, now car dies??
Any CEL codes? If not, try cleaning the IACV and adjusting the idle speed (see FAQs sticky).
Old 01-24-2011, 10:23 AM
decko's Avatar
I have cleaned the IACV and adjusted idle speed. I'm throwing codes
20 Electrical load detector
36 traction control found on JDM ecu's - this one I don't get, I'm not running a JDM ECU
Old 01-24-2011, 10:25 PM
00_civic757's Avatar
did u have these CEL's before u fixed ur vac leak?......has ur tach or speedo ever gone crazy for a split second?
Old 01-25-2011, 06:27 AM
It may help to reset the ECU. Also check whether the PCV valve or the PVC or breather hose is clogged.
tothewall
10-07-2010 12:43 PM
lsvteg11
09-17-2010 11:50 AM
DK4200
01-23-2004 11:27 AM
dsadas89das78934
01-15-2004 08:01 AM
Hondaaccordvtec
04-07-2003 08:15 AM
Quick Reply: Idle surging fixed, now car dies??
