Low Idle Issue
Low Idle Issue
My del sol has a d16 and im having some issues. If i am turning it on and off repeatedly like when running errands it will eventually crank then die. It starts normally then the rpms drop and just stalls. If i sit with the car off for about 10 minutes it will usually start back up. When it DOES start i am still getting a really low idle after driving a few miles. It idles at much less the 500 rpm. Yesterday i was sitting in a parking lot with the car on about to go into work and it starts idling lower and lower then the CEL lights up and dies a few seconds after. Once i got out of work it cranked right up and no CEL... i dont know what to do! any suggestions????
Check the code the ECU threw. Just because the light isn't on doesn't mean it isn't stored in the ECU. Get the code and report back so we can help you better.
Re: (HOUSTONtx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOUSTONtx »</TD></TR><TR><TD CLASS="quote">k. what kind of wire do i need to use to loop the ECU? just any kind of copper?</TD></TR></TABLE>
Yea Or Just Get A Paper Clip.
k. it was one long 3 fast flashes. so 13 correct?
that means the BARO-atmospheric pressure sensor
does that sound like it would cause the problems im having?
sound like the cure to my problems?
o and my plug was blue with a brown and black wire which is what the CEL thread says the EK's have but my car is a 94... does that sound right?
Re: (HOUSTONtx)
long flashes = 10 short = 1
your code is 30
Has anything been done to the motor? You could raise your idle on the throttle body by turning the screw counter clockwise, clockwise will lower it.
I would check your air filter too, it could be real dirty causing it to die.
your code is 30
nothing done to the car except an intake and a cat-back. and yes long flashes are 10 and i only had one long flash folloewed by 3 short flashes. so 13. anyone else had this CEL with similar symptoms? which screw is the idle control?
Modified by HOUSTONtx at 1:06 PM 7/10/2008
Re: (HOUSTONtx)
You Might Want To Check Your Spark Plugs/ n Wires. Also You Might Want To Check Your IACV, Which Could Be Dirty And Might Need A Cleaning. Have You Changed Your Fuel Filter Lately.
fuel filter has not been checked and neither has the IACV but im pretty sure the plugs and wires are all good. I just got a new air filter yesterday. What exactly is the atmospheric pressure sensor? and anyone know about the ECU? like i said the plug was blue like an EK but is a 94...pertty sure its a p28 ecu
Re: (HOUSTONtx)
You can't miss the idle screw, It's on the same side of the opening on the throttle body. There's a small flathead screw and it's a little recessed.
What year is your car? I don't believe you should be running a P28 unless you are boosting (turbo, supercharger) or trying to really tune a built motor. Try borrowing an ECU that goes to your car and plug it in. Which D16 do you have D16y8 or D16y7? I have both of those ECU's for sale by the way if you need them.
And like JDMPHILEP91 says you should clean and inspect your IACV which controls the idle. Sometimes I've heard that people cross the connectors of the IACV and the Map sensor which causes problems like you have. Both sensors are on the throttle body and have the same connector. Maybe try switching them.
Good Luck Dood
Good Luck Dood
Re: (Budget Racer)
I just found info on your code. I googled it ha ha
Here...
Code 13
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98 BARO Sensor (Atmospheric Pressure)
defective circuit or unplugged / defective sensor
I bet that's your problem.
Get a manual or search for the sensor location and plug it in dood or replace it.
Peace out!!
Here...
Code 13
Peace out!!
Thanks for the info about the idle control. and i know what the code is but i cant find anything on atmospheric pressure sensors! i remember seeing a line of numbers with P28 in the middle. thats why i think its a P28.
Re: (HOUSTONtx)
Did you try resetting the ECU by removing the under-hood BACKUP fuse for 30 seconds and then reinserting it? Afterwards, run the car to see if the problem recurs.
not yet, i will in the morning. which fuse should i pull? the under-hood main fuse and a back-up fuse? would unplugging the negative connection do the same thing
even if the CEL goes away after resetting the ECU my car is still having problems with the idle and turning on...
and i just checked the ECU list and the P28 is in the 92-95 civic si's and ex's. so im sure my 94 civic del sol uses the same ECU. and its a D16z6 i beleive
Modified by HOUSTONtx at 12:55 AM 7/11/2008
