electrical system: DEAD?
quick (probably stupid) question:
battery was hooked up (both terminals) and had a kid "arc weld" my strut bolt with the wire running off the + terminal line on the harness that has an end where a bolt passes through (no clue what the correct term for that is). i'm sure it sent a surge through the electrical system or something bad because now i have no electrical power at all. i turn the key to on, nothing happens. i can't roll up my windows, no lights anywhere, no sounds from anything turning on. dead.
could it be a relay or a fuse that might be blown from the little incident that needs to be replaced? no idea what's up here, someone has to know
thanks
thanks
Re: electrical system: DEAD? (2lua)
Yeah, check that fuse... it's labelled BAT (80A). That will probably be blown... hopefully that blew before the ecu fried...
HotImportNightHonda
13
05-22-2023 05:10 PM
bennjamin@ozhonda.com
09-04-2006 05:20 AM
FastHatch90
04-03-2006 07:47 PM
