car done for?
Old Sep 11, 2009 | 11:56 AM
bluestd's Avatar
Default car done for?
i accidentally hooked up the negative wire to the positive and the positive wire to the negative on the battery and now car is not getting any power, no fuel prime, no battery indicator on the cluster nothing. can someone tell me what happen and how to fix it or am i f'ed? thanks o and it's a 95 integra ls sedan if that matters
Old Sep 11, 2009 | 11:59 AM
TypeRMOBBiN209's Avatar
Default Re: car done for?
check your fuses and your battery
Old Sep 11, 2009 | 12:27 PM
solo227's Avatar
ECU might be fried
Old Sep 11, 2009 | 12:37 PM
Circusraven's Avatar
Sounds like a blow fuse. The ECU has a fuse that fries before it does, so hopefully it's still ok.
Old Sep 12, 2009 | 03:45 PM
bluestd's Avatar
wheres is the ecu fuse?
Old Sep 12, 2009 | 04:21 PM
.Manny.'s Avatar
Touching My Member
check the battery fuse inside the engine bay fuse box. I believe it is an 80 or 100 amp fuse. Everything else should be ok
Old Sep 12, 2009 | 05:01 PM
Micha's Avatar
FAILWGN
Look under your hood. Its right by the firewall on the passenger side. Check ALL of your fuses.
Old Sep 12, 2009 | 05:02 PM
Spawne32's Avatar
anything that has constant power probably blew a fuse, ignition, radio, interior lights, ecu, etc etc
bennjamin@ozhonda.com
Sep 4, 2006 05:20 AM
merch1
Mar 6, 2005 11:07 AM
Loudnissan
Aug 9, 2003 12:19 PM
PatrickGSR94
Apr 6, 2003 05:46 PM
4doorH22
Nov 27, 2001 09:48 AM
