EK Prop valve
EK Prop valve
46210-S04-901 VALVE, PROPORTIONING 99-00 Si
46210-S04-901 VALVE, PROPORTIONING 96-00 DX,CX,HX. Hb,coupes.
hondapartsunlimited.com
They are the SAME no need to swap them for a 4wheel disc conversion
Modified by jetpilot at 7:26 PM 6/5/2007
You are assuming they are the same becasue they come stock with drums, you dont know for sure.
Ive read they do have the same prop valves, at least the hatches do.
Can someone verify this
Re: (jetpilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetpilot »</TD></TR><TR><TD CLASS="quote">You are assuming they are the same becasue they come stock with drums, you dont know for sure.
Can someone verify this</TD></TR></TABLE>
I just did - edit - I also believe if you go online to a honda parts site & search they are the same part number that is cx/dx & si BUT NOT lx model trims
they look identical on the outside but i dont know if they are different.
Also all EX models should have the same prop valve cause they came with rear dics
Re: (jetpilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">The 96-00 DX and 99-00 Si share the same prop valve. I know because I have done this conversion a few times already. </TD></TR></TABLE>
Yes.CX,DX,HX,SI.All have the same prop valve.same part # = same part.
Re: (jetpilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetpilot »</TD></TR><TR><TD CLASS="quote">I searched on hondaautomotiveparts.com and didnt get the same part numbers.</TD></TR></TABLE>
They do not use Honda part numbers. But if you don't believe us go ahead and buy an "Si" prop valve.
Re: (jetpilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetpilot »</TD></TR><TR><TD CLASS="quote">I already have an EX prop valve just wanted to clear up the confusion with facts and not peoples assumptions or own personal opinions</TD></TR></TABLE>
I was not assuming or giving my personal opinion though, I was telling you.
kay_animation
08-26-2005 07:56 AM
