Ek electric problem??
i have a 97 ek. did a d15b swap. sometimes when i put the key in the ignition then turn it, ALL my power dies and i try to turn the key again and nothin happens. theres no light or anything. i pop the hood and open the ecu fuse box (dont even touch anythin) and my power comes back. this happend like 4 times already. i recently got foglights/sidemarkers installd if that makes a diff? what could be wrong?
Re: Ek electric problem?? (ph0shizzle)
did it just start doing this when the markers were installed? Check the ground on the thermostat housing and the battery terminal connections. Are the foglights powered directly to the battery? Make sure the battery terminals are clean and tight.
bump2pass
04-04-2016 07:29 AM
92EG8
06-03-2007 03:11 PM
