EK axle Prob Please help.. Exp Tech.
96 coupe ex and 99 GSR swap has bad axle vibration. Seems to be from left outer axle. Stuck 2 reman axles in there and didnt change. The car is dropped on cheap coilovers raising them makes it worse, a strait shot from the hub to the trans or intermediate shaft. Dropping the car (too low to be practical) helps alittle. I even tried shimming the motor mounts leaving the drivers lower torque mount loose and putting washers under the drivers mount which helped a little. The only other thing I can think of is that I used a 99 si T Belt bracket on the Gsr block. Gsr's have a higher deck hight right? Would that be enough to cause the trans to sit that **** eyed?
Thanks
Dave
Thanks
Dave
Stonage07
17
02-11-2017 05:11 AM
BoostJockey
09-06-2007 04:40 AM
ScottEK
08-23-2006 04:58 AM
