Car Not Cranking Over, 97 Civic DX
Old 08-31-2007, 01:26 PM
Lasty K's Avatar
Default Car Not Cranking Over, 97 Civic DX
Just finished swapping in a fresh y7 yesterday, ran and everything. Got a new dizzy cap, spark plugs, ignition wires, new battery too.
It's a stock d16y7, nothing else. Ran fine yesterday, but went to start it today and it would only do a clicking noise. Lights on the dash and everything shows up.
But I noticed while driving it last night, battery light came on. It would flash on and off some times...then when I got home, it stayed on. I'll try jump starting it and test the "new" battery I got though.
But if that's not the problem, any other thoughts?
Thanks.
Old 08-31-2007, 01:45 PM
Lasty K's Avatar
Old 08-31-2007, 01:57 PM
b16hatchsi's Avatar
same thing happed in my car. the battery you bought is more than likely a defect. take it back and get them to switch it for another one and you shouldnt have any problems. thats what i did anyhow, and havent had any problems since.
Old 08-31-2007, 02:16 PM
Lasty K's Avatar
Yea, that's what I'm thinking. The battery is called "Astro Power" or some bullshit lol
Old 08-31-2007, 02:21 PM
DeadVet's Avatar
Default Re: (Lasty K)
If the lights on the dash come on and the headlights come on then i doubt its the battery. Does it just click once or a series of clicks? More than likely it is the starter. Check for power at the big wire on the starter and if you have power there then check for power at the small wire while someone is trying to crank it.
Old 08-31-2007, 02:23 PM
Lasty K's Avatar
At first (before it died like this), you can hear multiple clicks, then later on, it just stays to 1 click.
Old 08-31-2007, 02:28 PM
DeadVet's Avatar
If it is a series of clicks its more than likely a dead cell in the battery. Take it to autozone or wherever and have it tested for free
Old 08-31-2007, 02:33 PM
Lasty K's Avatar
Default Re: (1TurboHatch)
Oh fosho, thanks for the input.
Anyone else wanting to give their 2 cents, chime in!
Old 08-31-2007, 04:40 PM
b16hatchsi's Avatar
my lights, radio, and everything electrical worked when i turned the key. yet it was still my battery that prevented it from cranking, and it wouldnt hold a charge.
Old 08-31-2007, 05:03 PM
Lasty K's Avatar
Default Re: (b16hatchsi)
Just went back down there to check the plugs on the starter. Tightened things up, cleaned some corrosion away from the battery terminals. Tried starting it up, I get a series of clicks now.
Old 08-31-2007, 05:05 PM
eskimo10's Avatar
Everybody is pointing at the battery, but when my car started having issues like this it was the voltage regulator inside the alternator. They symptoms of my car were -
not starting, but when i got it started it ran just fine
everything would dim (terribly, as in cut off dim) when my subs hit
my HU would cut off when i flipped the lights on
i would suggest first jumping it. then take the positive terminal off of the battery, if it cuts out your alternator is bad. If it stays on, let it run for a good while and hook it up to the battery to charge it and then cut it off and try to start it again and see what happens. If you can't start it your voltage regulator is bad. Hope that helps
Old 08-31-2007, 05:32 PM
Lasty K's Avatar
Went to check again haha, turned on the headlights and the lights on the cluster dimmed horribly.
We'll see what happens tomorrow though.
Old 08-31-2007, 07:20 PM
eskimo10's Avatar
I would definetly try replacing your alternator... I know thats expensive as nuts but that should cure it. If you take it to a store like AutoZone or Advance they can't exactly diagnose this type of problem b/c the alternator works fine when running. Anyway keep us updated and let us know how goes it.
Old 08-31-2007, 07:24 PM
Lasty K's Avatar
Will do.
Old 09-01-2007, 05:30 AM
b16hatchsi's Avatar
im just speaking from experience. would definitely get an exchange on the battery before spending a lot on a new alternator.
Old 09-01-2007, 07:39 AM
petermike's Avatar
boost the car, your battery charge is too low, you probably try to many times or you have a bad ground ... me i have a similar problem with a d16z6 after we wash the motor.. it doesn t start at all, we have fire in cylinder, fuel to injector.. can't check if they open when we try to start .. but i guess , dizzy cap is plug properly in fire order 1-3-4-2 , 1 starting at C point on the cap.
I think maybe a bad ground could cause that.. but im not familiar with multimeter to check all ground to see .. someone have an idea or can refer a pro for that in montreal..
Old 09-04-2007, 07:19 PM
Lasty K's Avatar
Replaced the alternator, started up fine.
That's what it was lol.
Thanks for the help and input everyone, I'll use it for future references.
Old 09-05-2007, 03:21 AM
eskimo10's Avatar
Awesome man, glad to hear everything worked out for ya!
Old 09-05-2007, 04:16 AM
mikesEK's Avatar
same **** happened to me after a R&R on my EK,,,,and after trouble shooting ,I found out it ,I didn't really tighten the ground from the chassis to the motor ,,,,,tightened it up and everything was gravy!!!!!((the one coming of the tranny on passengers side))
meisnick
07-30-2017 06:43 PM
Declan Bostock
12-01-2014 10:07 AM
stupendousman
Honda Civic (2001 - 2005)
17
01-02-2013 08:40 PM
Hanmin
07-27-2010 08:11 AM
JDM*addiction
08-06-2006 08:58 AM
Quick Reply: Car Not Cranking Over, 97 Civic DX
