EG8 altering the blinker/Indicator/turnlights ***help please***
(this is my first post!!)
Hi,
I live in Australia, and with the cars here, when you turn on the headlights the indicators/turn lights/blinkers don't go on, they just blink when you use your indicator and this no different for my EG8, where as most cars in the US have the blinkers on constantly when you have the headlights on. and when you use your indicator they start blinking.
an example of what i mean:
http://plasmagarage.com/sitebu...6.jpg
http://photo.ringo.com/164/164380159O286505679.jpg
if some one could help me do this I would most thankfull
Hi,
HT White Ops
First thing you'd have to do is source a set of bulb sockets that has a three-wire setup (ie, a USDM socket), and then use a dual-filament bulb.
From there, you'd remove the pins from your stock socket, and repin the new socket. Then run a wire from the third spot and tap it into your city light 12v switched wiring so both your city lights and your corners light.
crazy eyez killa
08-18-2004 08:20 AM
