any reason why JDM/European corners stay off while USDM stay lit up?
Old 08-17-2004, 05:29 PM
crazy eyez killa
Guest
Posts: n/a
Default any reason why JDM/European corners stay off while USDM stay lit up?
Im curious what the reason is behind the 2 different setups...
Is it because EDM/JDM Civics have sidemarkers as well?
Old 08-17-2004, 05:33 PM
Luserkid's Avatar
Default Re: any reason why JDM/European corners stay off while USDM stay lit up? (YOUR MAMA)
What exactly do you mean by "stay lit up"?
Luserkid is offline
Old 08-17-2004, 06:15 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: any reason why JDM/European corners stay off while USDM stay lit up? (Luserkid)
Like if you turn your headlights on in america, the corner light stays on, and blinks brighter when you hit the turn signal...
In europe (and i think japan too) the headlights will be on but the corners are off, they only light up when you hit the turn signal. But they have sidemarkers which are on instead...
Old 08-17-2004, 06:32 PM
Luserkid's Avatar
So if you click your lights once to turn on your corner lights only what turns on? The side markers? Arent you suppose to use that in the fog instead of your headlights?
Luserkid is offline
Old 08-17-2004, 07:26 PM
* B A N N E D *
Possible, but its all marketing. Could be some laws want it. There are fixes for that. I did it. Take out the bulb, and put a piece of electrical tape over the metal contact point on the bulb for the 5W (not 22W) contact, meaning the contact to the bulb for the lower filament that runs all the time. Or pull the wire (search for its location). Or cut that wire.
Redline96LX is offline
Old 08-18-2004, 08:20 AM
crazy eyez killa
Guest
Posts: n/a
Default Re: any reason why JDM/European corners stay off while USDM stay lit up? (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">Possible, but its all marketing. Could be some laws want it. There are fixes for that. I did it. Take out the bulb, and put a piece of electrical tape over the metal contact point on the bulb for the 5W (not 22W) contact, meaning the contact to the bulb for the lower filament that runs all the time. Or pull the wire (search for its location). Or cut that wire.</TD></TR></TABLE>
Do you have sidemarkers?
pearlteg
11-25-2004 08:06 PM
RicedREX
10-14-2003 06:21 PM
BoostedGSRBubble
10-09-2002 11:58 AM
.paul
03-23-2002 09:42 PM
SpeedracerS4
10-05-2001 06:38 AM
Quick Reply: any reason why JDM/European corners stay off while USDM stay lit up?
  • Ask a Question
Question Title:
Description:
