eg starting problem
eg starting problem
Hello HT, my eg is not starting again for some reason. Its stock with a d15b7 and about 250k. I have done/checked
dizzy wires
alternator
starter
spark plugs
battery
battery posts
checked all fuses
but it still won't start, I have a kill switch connected to starter and thermostat housing but I hear it going on when I turn the key over. It does not get any spark whatsoever, no clicking no nothing. I'm not sure what,the problem is, if you can help I would really appreciate. Thank you
dizzy wires
alternator
starter
spark plugs
battery
battery posts
checked all fuses
Re: eg starting problem
From your description it sounds like you are saying it is not even cranking let alone not starting. Is this correct?
If so, how did you check the starter?
HybridGSR1
07-13-2004 02:16 AM
