Engine starts problem
Old May 11, 2009 | 10:30 AM
Honda13's Avatar
Icon3 Engine starts problem
Hi guys, I have a 1996 Honda Accord Sedan Ex model. My starter died out last week and I replaced it. For the first couple days it starts with no problem at all. Until yesterday morning it didn't start after a couple try.
I was wondering what's wrong with the car? Is it cap and rotor needs to be replace? Spark plugs and spark plug wires need to be replace as well? Thank You for your help.
Old May 11, 2009 | 11:04 AM
95LxCD5's Avatar
Default Re: Engine starts problem
does it turn over at all?
Old May 11, 2009 | 11:31 AM
Honda13's Avatar
First try it does not turn over at all. Second try it will start
Old May 11, 2009 | 11:32 AM
95LxCD5's Avatar
you may wanna replace your battery if it doesnt even turn over.
Old May 11, 2009 | 12:39 PM
Honda13's Avatar
Battery has been replace recently as well
Old May 11, 2009 | 02:10 PM
Mr Yamada's Avatar
What kind of "won't start"
Does the starter spin the engine?
Old May 11, 2009 | 03:13 PM
FTW_Accord94's Avatar
check starter ground...may be loose? does any crank at all when attempting to start?
Old May 11, 2009 | 10:47 PM
Honda13's Avatar
I won't even crank (no noised) on the first try.
Old May 12, 2009 | 05:06 AM
GhostAccord's Avatar
Check both your battery and starters (+) & (-) connections. Sounds like you may have a loose or dirty connection.
Old May 12, 2009 | 08:12 AM
jerrym88's Avatar
i had the same problem and i what i did i replace the spark plugs and then put a brand knew main relay, and now its back to normal. try it. cuz if your starte is good and your battery then it maight be the main realy.
Old May 12, 2009 | 08:31 AM
Honda13's Avatar
Sorry for the noob question but where is the main relay located?? Any picture would be appreciated.
Old May 12, 2009 | 09:04 AM
jerrym88's Avatar
well its located right under the steering wheel, its right behind the cruise control button.
Old May 12, 2009 | 09:13 AM
billyrusa's Avatar
If the starter does not crank, it is unlikely the main relay problem. At least, check the battery connections and ground first.
Old May 12, 2009 | 01:54 PM
Honda13's Avatar
So.... I took out the spark plugs today and what I see on the bottom of the spark plugs thread are yellow brownish color. Also the spark plug wires connecting to spark plugs have white stuff on them as well. Is that the reason why my car is hard to start in the morning? Thank you for your input.
Old May 12, 2009 | 02:29 PM
If you have a no crank issue the plugs will have nothing to do with your problem. If you have a cranking engine with no start it could be a possibility. But they would have to be severely corroded.
Do you have any pics of said corroded plugs?
If they are corroded and dirty enough then yes you should replace them. Are they so corroded that you couldn't clean them up and see if that's your problem?
Old May 12, 2009 | 07:32 PM
95LxCD5's Avatar
well if i pulled my spark plugs out and they looked like they were dipped in poo then i would replace them...but thats just me. they are only about 5 to 15 bucks a piece and are an easy fix. and theres only 4...lol at V8s
Old May 12, 2009 | 07:35 PM
95LxCD5's Avatar
fuse? maybe? worth checking in my eye
Old May 12, 2009 | 07:40 PM
A light brown coating to the spark plugs insulator isn't bad, it's actually normal. Yes I agree that if they look like they were dipped in crap, I would also replace them. That's why I would like to see pics of said spark plugs. Or you could just keep throwing parts at this problem and eventually it will start. for neanderthal troubleshooting.
Old May 12, 2009 | 07:48 PM
95LxCD5's Avatar
LMAO. Ug need more parts.
no offense to the TC
Old May 12, 2009 | 07:49 PM
95LxCD5's Avatar
but remember. if its worth doing, its worth over-doing.
Old May 12, 2009 | 07:52 PM
95LxCD5's Avatar
ok. puts serious face on.
Old May 12, 2009 | 10:40 PM
nus_dogg's Avatar
Is your car 5spd or auto? Mine's a 5spd and sometimes the ground wire tends to come off by itself. It's the wire that clips into the starter and it comes out from the engine harness. You'll be able to tell. If that comes loose, your motor won't crank over at all.
Old May 13, 2009 | 08:36 AM
Honda13's Avatar
My car is an automatic. I will check the ground wire connecting to the starter today and keep you guys posted. I have questions though. How come it only hard to start in the morning after overnight park though? After I got the car started, it's starting fine the whole day?
whit3tatt3dn3rd
Jun 24, 2013 10:40 AM
Type_R_Lover
Jan 19, 2010 06:19 PM
jorge59la
Aug 15, 2007 07:32 PM
PurEvl
Dec 11, 2005 05:55 PM
aeon
Jul 17, 2004 09:40 AM
