00 Civic SI no start
Old 01-17-2013, 10:20 PM
civicsi509's Avatar
Default 00 Civic SI no start
My civic wont start it cranks and it has no ignition issue i have my fuel pump wire to a switch and that is working just fine i just replaced it thinking that was my issue i also replace the fuel filter and spark plugs. It has spark and the pump is working i can not figure out why it is that it wont start please help..
Thank you
Old 01-17-2013, 10:30 PM
hwyix's Avatar
Default Re: 00 Civic SI no start
Did you test for spark with HEI tester like this? The voltage necessary to fire the HEI Spark Tester is around 35,000 volts.
When was the last time your car ran? What has changed since then?
Old 01-18-2013, 07:22 AM
hwyix's Avatar
I don't know why I missed this last night. This might be causing you more problems. Post a diagram on how you wired it. A fuel pump is a high current device ( like a head light ). You can't just wire a switch to it.
When I was 20 (cough cough a long time ago) I had a porsche 914 that the ignition switch went out. I thought I was cool/smart because I by passed the switch with a cool push button ( like s2000 ). I burnt out two switches before I figured out what I was doing wrong.
Old 01-18-2013, 08:39 AM
Former User's Avatar
Your need to bypass the main relay and wire the fuel pump directly to voltage suggests:
1) The main relay is bad and needs resoldering.
2) Fuse 44 or 13 is blown.
3) The G101 ground on the thermostat housing is disconnected, loose, or corroded.
4) The ECU is bad.
Check these^ and then go from there.
When you solve the problem, then rewire your fuel pump and main relay to stock. The main relay is a fire prevention device that stops the fuel pump from running after an accident when the car has stopped.
civhatch4life
09-12-2012 12:08 PM
DA_zooooms
05-12-2008 07:16 PM
po0tie
02-17-2008 09:46 AM
1baddcivicsi
26
10-13-2006 04:17 PM
Frito1
04-06-2002 07:59 PM
Quick Reply: 00 Civic SI no start
