EG Si Problem. Removed Valve Cover When Replaced Car Runs Like Crap! Help ASAP!
A friend took off his valve cover to paint it. Then he put it back on. Now his car runs like crap. I went through all the normal things about valve cover seal and such and it doesnt seem to be the problem. He didnt break any sensors, didnt damage anything. He and I are stumped.
No oil on the spark plugs or spark plug wires. Everything is connected correctly to the dist.
Any ideas?
Thanks
CRX Forum
Any ideas?
Thanks
CRX Forum
this is y i said check the dizzy!!! but yeah if you dont have that ground it will run like **** ive done it before and guys just to let you know i whole heartedly believe in the spider grounds buy them they work wonders i put it on my b and better throttle response and everything for some reason its just awsome buy it go now
Re: (SkertySkerty)
It seemed to be his valve cover seal. There was oil on almost all sides of the motor around the seal leaking down the head. He also didnt have his valve cover grounded. I told him to do that aswell as replace the seal. He also somehow broke off a valve cover bolt in the head and that one point is loose. So hopefully he will be able to drill and tap that out so that side is sealed aswell. That seems to be the problem there is nothing else going on that I can see or that we noticed other than those things.
CRX Forum
CRX Forum
hondamark35
05-02-2007 12:35 PM
wowowee
24
07-19-2005 05:04 PM
