Eg rear control arm
Eg rear control arm
Hi every body,i own a civic Eg,and i want to install to my car a racing suspension from Ek model but the main problem is the rear control arms because is longer.I dont want to use aluminioum arms because the car is for gravel use.Has anybody any ideas which contol arms(rear) is suitable on eg with ek suspension?Thanks.
Re: Eg rear control arm
Seagull Management
The front shocks and springs bolt on. You'll need to use hose clamps or ty wraps to hold the brake lines since the brackets aren't there. For the rear you'll need to cut a little off each side of the shock bushing in the lower control arm since the rear shock forks on an EK are narrower, you'll also need to use shock bolts for an EK.
BrianFreels
05-04-2009 01:36 PM
hifonics
10
07-03-2007 02:36 PM
Demon_Dub
09-25-2005 01:18 PM
