EG interior question! help plzzz
im putting in a new dashboard, gray to black, in order to do this i have to drop steering column right?
my friend said two bolts i need to take off in order to drop is underneath by the steering column not sure on the socket size...deep socket 14 or 12?
and one more thing im installing carpet what size sockets i need for chair bolts?
Re: EG interior question! help plzzz (nub_pwn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub_pwn »</TD></TR><TR><TD CLASS="quote">not sure on the socket size...deep socket 14 or 12?
someone ask him if he even has a repair manual for the car!
if you do, it should tell you where everything is
Re: (eg ferio)
Steering column bolts are 14mm, may have to use deep socket. then you will have two mount bolts on the end, one in the center underneath the vent on top of the dash, and a couple of miscellaneous bolts undereath. Should probably take off glove box. Don't have to but would be good idea. Bolts for seats are indeed 12mm. GL. Also don't try and pull the dash off until you make sure you have all the connections off.
SloCivicHMM
07-21-2004 03:16 PM
