why wont this fit on my s4c trans?
on this bracket the bottom 2 bolts wont line up with the ones on my 2000 civic si trans but its the only bracket i could find that will fit onto the motor mount i have (the one on the rear cross member)
this is the bracket i have that will fit right onto the transmission again a 2000 civic si trans but wont fit on the motor mount that i have
you can see how the pic on top sets the mount off to the left and this one sets it off to the right
i need the bracket that will fit on the tranny and set the mount off to the left like the t-braceket in the top pic does that does not fit my motor
any sugestions
btw all im trying to do is put an ls in a EG and this rear mount is really being a pain in the ***
any sugestions
Re: (si0385.)
The 2000 civic si rear mount won't work in a b-series to eg swap. (you know that now). you need the rear mount from a 94-95 del sol vtec. maybe some other mounts will work too but the only one I know is that one ^. I did a JDM 2nd gen b16 swap in my 98 lx and I had to use a 00 si rear mount because the one that came with the motor did not fit. I still have that rear mount. if you want i'll sell it too you. the rear mount i have is off my JDM 2nd gen OBD1 B16a. It will work for any b-series to eg swap,!!!
Re: (si0385.)
My fault. What I was saying is that you need the 94-95 del sol vtec "t-bracket". I've always called it "rear mount". The mount thats on your eg frame stays where it is, then you need the del sol t-bracket and thats it. Like i stated above to put any b-series in a eg you need a 94-95 del sol vtec rear t-bracket or similar. If you have this mount then something else is off alignment.
Re: (si0385.)
Thats all you need man (non 99-00 si bracket). Your putting a B-series motor in an eg. you don't need anything special. Its not like putting a b-series in a ef. Do a search here on honda-tech for "ls swap" or "ls in eg", or "b18b in eg", etc, etc. Its gonna be a bitch to install, not easy at all!!!! I helped my buddy put a OBD1 JDM b16a in his 92 civic hatch back. We used the mounts that came with the motor.
here I did a search: It says you can use a 94+ rear mount (the same as del sol vtec)
https://honda-tech.com/zerothread?id=1257275
Re: (eg crunkmonster)
yeah i had trouble w/ my lsvtec swap tried to use the da bracket that was on the mtr. luckily found 94 and up integra that night that was the worst mtr swap experience the ls vtec swap too much stuff
Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">I hate that stupid rear bracket. I have 4 different onces because I couldn't get mine to work at first either.</TD></TR></TABLE>
what bracket did you wind up using...
i cant believe its this hard to find out what t-bracket you need to make an s4c tranny work in an eg... iknow there are tens of thousands of eg's on here with 2000 si swaps i think you guys are just holding out on me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg crunkmonster »</TD></TR><TR><TD CLASS="quote">i told u, 94+ integra rear tranny bracket will work, ive done like 20+ swaps, i know</TD></TR></TABLE>
idk wahts goin on i will take pics of that exact braket in the top picture not lining up on my tranny and thae one on teh bottom not lining up on my car
si0385.
22
09-09-2006 12:28 PM
