My bracket doesn't fit !!!!! Need help!!!
Hey guys I'm in the proccess of swapping my b16 into my 95 eh but i'm running into a little problem. The rear "L" bracket doesn't want to line up with the holes. I'm using a 94-01 integra manual bracket, I have read that the bracket should fit fine. Someone told me I need the 99-00 SI bracket. Is this true?
Re: My bracket doesn't fit !!!!! Need help!!! (jDmImagE)
L bracket, what is this thing you speak of?
explain more, is it the upper tranny mount, or the lower?
Re: My bracket doesn't fit !!!!! Need help!!! (SirRevvs)
they dont line up.. when i put motors in i only put the drivers side big mount on and the big tranny mount.. not the tourqe or anything else.. that way when you go to put tha t bracket in you can move the motor to make all the holes line up and it helps put it up in there when you move the motor
Re: My bracket doesn't fit !!!!! Need help!!! (siregcivic)
Is the motor in the car or just sitting on the floor? If its out it should fit no problem. If the motor is in the car youll have to shimy and shake the motor a bit for them to align...I usually take a crow bar to the motor for this.
sometimes i use the factory honda jack between the firewall/steering plate and intake manifold to give it a little push
corollagts33
12-07-2005 10:37 PM
