Auto to Manual Conversion Help!!
I have a 97 automatic civic and i would like to know what are the transmission mounts/brackets i need to complete the swap? I get many different answers so i would like to know what i NEED to make this swap possible.
Pictures would be extremely helpful...
Ferio Wdm Edition
Re: Auto to Manual Conversion Help!!
All you need is the tranny, and the tranny bracket. Shift linkage, must be d series. Obd2a ecu, wire up the reverse, and clutch switch to start the car, youll need manual flywheel bolts, as the auto ones are too long iirc... Manual brake booster, auto will not work..theres more i believe, if i remember, ill add
brake booster is the same. you also need manual starter+bolts,clutch and brake pedal's,,rear t-bracket,ps torque mount on tranny , rear mount . there is a good guide in the faq
danwants2btheman
09-13-2006 12:33 PM
