Ecu Code1 Oxygen Sensor bad cat catalytic converter?
i just threw on the old cat and i am getting loss in power, a surging idle and cel #1.
could the problem be cause by the old cat? or is it just a coincidence that the o2 sensor went bad at the same time?
Re: Ecu Code1 Oxygen Sensor bad cat catalytic converter? (thisisntjared)
up.
man i thought this would be easily answered... it seems like a stupid question. unless i am getting a code 10 for iat
i checked out all my o2 wires and found 2 of them loose (orange and green) i thought those were for the heater, would that cause my problem?
CEL 1 should never be due to a cat, the primary O2 is pre-cat.
I'm assuming you're talking about your EG and an OEM O2....
at the O2
black/black - heater wires
white - O2 signal
orange - O2 ground
at the engine harness to the O2
yel/blk - 12V ign to O2 heater (black)
orn/blk - O2 heater control (black)
wht - O2 signal (white)
grn/wht - ground (green)
at the O2
white - O2 signal
orange - O2 ground
i mustve knocked something loose when i installed the cat.
yes i meant my eg and i have some non oem o2 though.
i reconnected the wires and no code after 1.5 hours of driving.
DFW
09-20-2006 11:01 AM
