ECU Code 43 What do i do????
Old 10-05-2004, 07:17 PM
vtec25's Avatar
Default ECU Code 43 What do i do????
43 - Fuel supply system
what is it that i have to replace??? i dont know what to do for this one.
i also got a code 1 but atleast i know i have to change the o2 sensor.
Old 10-05-2004, 07:20 PM
flatty's Avatar
the code 43 could have some thing to do with the o2 sensor problem
Old 10-05-2004, 07:21 PM
flatty's Avatar
bump
Old 10-06-2004, 01:45 AM
vtec25's Avatar
Default Re: (dundulk si)
hmmmmmmm.
anyone else idea's? or knows for sure
Old 10-06-2004, 02:17 AM
JDMlyfestyle's Avatar
fuel supply system...hmmm... fuel pump, fuel filter, regulator, ect.
Old 10-06-2004, 03:30 AM
menkio's Avatar
Default Re: (JDMlyfestyle)
bring it to a dealer
Old 10-06-2004, 05:15 AM
EE_Chris's Avatar
Default Re: (yanta)
The O2 sensor is what trips this code [43] to begin with....have you replaced the O2 sensor yet and reset the ECU?
Old 10-06-2004, 06:01 AM
bootlegtrader's Avatar
Default Re: ECU Code 43 What do i do???? (vtec25)
Same thing happened to me. (95 del sol jdm b16a2)
This is what still HAS NOT fixed the problem:
NEW cap+rotor
NEW spark splugs
NEW ignition coil+assembly
NEW fuel filter
NEW O2 sensor
I am taking it to have the whole fuel sytem cleaned this week. $80 and they pump some hot oil **** through your fuel rail and it cleans out your injectors and intake valves. My a/f gauge was is usually way lean, but sometimes it goes extremely rich and starts to bog. I gota take this **** in. Good luck.
Modified by bootlegtrader at 9:12 AM 10/6/2004
Old 10-06-2004, 06:09 AM
Former Moderator
B18C5-EH2's Avatar
Default Re: ECU Code 43 What do i do???? (bootlegtrader)
Fuel supply code goes hand in hand with the oxygen sensor code.
Replace the oxygen sensor with a OE HONDA one and you'll clear both codes.
Use a ****-Bosch one or another el cheapo one and you'll probably just get even more pissed when the code resurfaces.
The only aftermarket 02 I'd even consider owning (I actually have one in my 1990 Civic) is the NTK direct-plug in o2 sensor. They're a lot cheaper than OE and plug right in, but in the long run nothing beats the OE units.
Old 10-06-2004, 08:21 PM
vtec25's Avatar
Default Re: ECU Code 43 What do i do???? (B18C5-EH2)
dont know it'll help to say but the cel dont go on right after i start the car it takes like 25mins. to go on.
and thankx to all
Old 10-06-2004, 08:28 PM
vtec25's Avatar
also i forgot my gas tank is dent in could that have something to do with it???
civiccarbuff
09-18-2008 08:29 PM
manuel3655
05-24-2007 06:22 AM
PhilStubbs
01-22-2005 11:20 AM
importimage
06-30-2003 04:27 PM
blkDOHCsol
01-28-2002 07:38 AM
Quick Reply: ECU Code 43 What do i do????
