is this ecu chipped?
can somone tell me if this ecu has a tune/chip
http://i53.tinypic.com/23kerk1.jpg http://i53.tinypic.com/ao2qt4.jpg |
Re: is this ecu chipped?
bump
Is this ECU for an airplane? what?
yes it is. see arrows :bag::thud::thumbup::beer:
http://i185.photobucket.com/albums/x...jdm/ao2qt4.jpg |
as far as tuning who knows what the basemaps are, only way to find out is to take it to a tuner
It's chipped, but they soldered the chip in an it will be a pain to get it out. If you can snip the legs off the chip, it will be easier to remove the chip without damaging the board.
legs don't look soldered in to me?
Originally Posted by crxsisohc
(Post 45501003)
Originally Posted by grumblemarc
(Post 45501182)
It's not. Only the ZIF socket is soldered to the board.
OP: i would be very careful when removing the chip. when you get it up add a ZIF socket for easier install/removal later. |
Originally Posted by NotAJDMFanBoy
(Post 45500917)
A couple of macro shots of the socket+chip area will help. |
In any case. The chip shouldn't be soldered. It doesn't look like it is to me but that might be due to the low quality of the pic.
if its chipped why take it out isnt chipped ecu good???
Originally Posted by cleepyek
(Post 45504069)
chipped is good if it's needed. but it can be just as bad as good if the data on chip (or the tune... or the basemap...) is crap. also in most cases the chip must be removed to be "burned" or reprogrammed. |
