ebrake cable replacement
not sure what to do here....
from the look of it, I have to removed part of the exhaust and the heat shield from underneath the car. but I don't know what to do next... btw, I have a 93 civic ex.
thanks!
Wayne
thanks!
Wayne
Re: ebrake cable replacement (sanjiyan69)
Try removing the center console between the front seats to get a better view of where the cables connect.
Make sure you loosen the tensioner all the way before installing the new cables to make it easier to connect everything.
yeah, take off or lower the exhaust, take the heat sheild off, and you will see exactly what you have to do. There are a couple of brackets on each side that hold the cable to the chassis. You need to take off the center console to disconnect the cable from the handle. Once you tak a look at everything it should be self explanatory.
outgunned
Honda Civic (2006 - 2015)
01-01-2013 05:53 PM
