1999 Civic 5 Speed Shifter Rod
I'm having a hard time removing the shifter rod from the trans. I have removed the spring pin but can't ge the shifter rod off. Any tricks would be a help.
Thom
Thom
Re: 1999 Civic 5 Speed Shifter Rod
Yes, I removed the spring pin 28. I can't get the shaft to put off. I will try the pen. oil and see if it loosen up.
So I have tried penetrating oil and I still can't separate the shift rod #14 from the transmission. I'm afraid if I really hit it I will damage the inside of the trans. HELP!!!!
P.S. Yes I have removed the spring pin #28.
Really. Someone else must have had this problem. I'm thinking about putting some heat to the coupler to see if that break it loose.
Just to follow-up, I had to remove the transmission with the rod attached. Once out of the car, I had to heat the coupler and then spray liquid wrench in the spring pin hole. This allowed me to break the shift rod from the coupler. What a pain in the butt! Thanks for all you help!
T
T
averyvm
10-27-2007 06:49 PM
What makes the gear shifter spring to the center of the shift pattern? Is it in the Transmission, or
dave1234
07-27-2006 09:51 AM
