1999 Civic 5 Speed Shifter Rod
Old 10-23-2012, 12:29 PM
drsab2000's Avatar
Default 1999 Civic 5 Speed Shifter Rod
I'm having a hard time removing the shifter rod from the trans. I have removed the spring pin but can't ge the shifter rod off. Any tricks would be a help.
Thom
Old 10-23-2012, 01:15 PM
Ridin Dirty in Cali
dirty19's Avatar
Default Re: 1999 Civic 5 Speed Shifter Rod
Spray some penetrating oil where it connects.
Let it sit, then try with a flat tip screwdriver to get it to separate.
You did remove pin number 28 correct?
Old 10-23-2012, 01:50 PM
drsab2000's Avatar
Yes, I removed the spring pin 28. I can't get the shaft to put off. I will try the pen. oil and see if it loosen up.
Old 10-25-2012, 07:29 AM
drsab2000's Avatar
So I have tried penetrating oil and I still can't separate the shift rod #14 from the transmission. I'm afraid if I really hit it I will damage the inside of the trans. HELP!!!!
P.S. Yes I have removed the spring pin #28.
Old 10-25-2012, 07:34 AM
kyden's Avatar
get in the car, slam 3rd gear a few times and see if it'll pop out of the transmission.
Old 10-25-2012, 09:56 AM
guessohw's Avatar
I like your style lol.
Old 10-25-2012, 02:39 PM
drsab2000's Avatar
Really. Someone else must have had this problem. I'm thinking about putting some heat to the coupler to see if that break it loose.
Old 10-25-2012, 02:47 PM
Master Detailer
98civdx's Avatar
Do what kyden said.
Old 11-04-2012, 10:59 AM
drsab2000's Avatar
Just to follow-up, I had to remove the transmission with the rod attached. Once out of the car, I had to heat the coupler and then spray liquid wrench in the spring pin hole. This allowed me to break the shift rod from the coupler. What a pain in the butt! Thanks for all you help!
T
minitruckskunk
Transmission & Drivetrain
07-06-2017 07:57 PM
rsr001
05-02-2007 10:36 PM
iown2
11-29-2003 08:53 PM
Quick Reply: 1999 Civic 5 Speed Shifter Rod
