e-brake light always on
Old 05-06-2002, 05:44 PM
ACTEG's Avatar
Default e-brake light always on
the parking brake light is always on, any ideas?
Old 05-06-2002, 06:16 PM
TurboBumblBee's Avatar
Default Re: e-brake light always on (ACTEG)
check to make sure something isnt grounding out the switch under the ebrake handle and also check to make sure that your master and slave cynlinders are at the correct level of fluid.. if these things check out you have a bad switch or wiring problem under the dash..
Old 05-06-2002, 06:37 PM
civicb18b's Avatar
Default Re: e-brake light always on (95CivicEX)
i am 99.999999 percent positive that your brake fluid is low. check all brake lines asap!!!
civicb18b's Avatar
Default Re: e-brake light always on (civicb18b)
all lines include steel and flexible!
Old 05-06-2002, 07:06 PM
i only say check the ebrake switch cause i once lost a socket and it was triggering it off/on/off etc while i was driving.. but also do make sure that you have plenty of fluid in there also cause i know it will do the same effect.. maybe have the brakes fleed really well also now to make sure all the air is out..
Z20rider
Honda Civic (2001 - 2005)
11-30-2015 07:21 AM
pfourtythree
04-10-2007 10:52 AM
Blk_Lude98
10-20-2006 07:27 AM
CRX T-Si
16
06-23-2006 11:30 PM
dd_biggy
03-09-2004 07:41 PM
Quick Reply: e-brake light always on
